If I remember correctly, v6.0 a NET Label could show the Negation bar above the text by using ~NetName~. Doesn’t seem to work with v7.0. Can’t do that now??? Not good if you can’t.
Any info? Thanks all!
OtG
In 6.0 the syntax is ~{label}
Dunno about V7.
If I remember correctly…
No, that syntax is way older. overbar syntax in v6/v7: ~{TEXT}
Also the help is only one click away: in every label-dialog there is a little blue link “syntax help”. You can try to click on that link.
Thanks for the great responses!
OtG
