[[ SOLVED ]] Moving my mouse causes KiCad PCB Editor to Flicker
Hi there!
This is annoying, I don’t even know if this is the right place or if I should open a bug…
Nevertheless, I just switched my computer over from a Surface Book 2 to a Lenovo Slim 7 PRO-X, then downloaded and installed KiCad 8.0.6, then restored the project files from the old computer.
Both laptops have two graphic cards (Intel + Nvidia on the Surface and ATI Radeon + Nvidia on the Lenovo), which I left running on the default (the first one).
Problem is, in the new laptop whenever I open any file, the schematics editor works just fine, but the PCB Editor gets flickering every time the mouse makes a move. If I force the display settings to use Nvidia with Kicad, it works fine.
Any ideas on why?
Thanks!
Here’s my Kicad version:
Version: 8.0.6, release build
wxWidgets 3.2.6
FreeType 2.13.2
HarfBuzz 9.0.0
FontConfig 2.14.2
libcurl/8.8.0-DEV Schannel zlib/1.3.1
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: ATI Technologies Inc., AMD Radeon™ Graphics, 4.6.0 Compatibility Profile Context 23.10.24.02.230811
Date: Oct 14 2024 01:02:33
Boost: 1.85.0
OCC: 7.8.1
Curl: 8.8.0-DEV
ngspice: 43
Compiler: Visual C++ 1939 without C++ ABI
I think it’s best to report this to AMD.
I’ve had similar problems with some things on Linux. My system is old. They seem to clear up at some point for reasons unknown. One in particular was on a website that I couldn’t put the mouse over one particular thing without it causing the item under the cursor to ‘shake’. Hard to add things to the cart. :wink:
I never knew if the fix came on my end or theirs.
Indeed, after downloading the AMD driver from Lenovo’s website and installing it, all got normal.
Thanks!
