[SOLVED] Messed with ground plane
Hi! I am new to pcb design and I think I messed with the ground and power planes as you can see, the shape is shifted and I can’t see the routing even though its done on the back layer. Can someone point where should I look for the error or maybe you need more details. Thank you in advance!
Have you tried pressing ‘B’ ?
As simple as that :sweat_smile:
Thank you!
You are most welcome, it’s only difficult until you know how, then it’s easy :wink:
Which software do you use? Could you offer the file?
A surprising question.
