I’ll piggyback on this topic rather than creating a new one as I have a somewhat related query:
I would like to experiment with KiKit, with Kicad 6 on Fedora 35 - at present I can only install Kicad 6 as a Flatpak (it won’t be included in the standard repos until Fedora 36, which is months away). Apparently the Flatpak-ed instance of Python doesn’t include pip so adding the KiKit backend has me stumped. I guess that it sort of goes against the spirit of Flatpaks to go in and modify/add things that could potentially break the Flatpak, (though adding things from the plugin manager works fine) but there must be a way around this? I would really like to avoid solutions that involve using a different operating system or using an older version of Kicad.
I’ve had a search around but possibly my search terms are not exactly right as I haven’t found anything that details interacting with the content of a Flatpak in this way…
Hi, I guess you run MacOS, right? Unfortunately, there are some problems with the GUI plugin in MacOS. I am not a mac user so I cannot help and investigate properly, but there a few users trying to find out what’s wrong. Read the relevant issue: https://github.com/yaqwsx/KiKit/issues/252
Did you follow the instructions and installed KiKit from withing “KiCAD command prompt”? KiCAD brings its Python a Pip so if you install it with any other Python, KiCAD won’t see it. And you cannot use the CLI as KiKit won’t see KiCAD.
Same here. Just installed 6.01. Then I installed Kikit via the plugin manager and then used the Kicad command line to setup kikit. However I am still getting the “kikit is not installed” dialog box. How do I fix this? Thanks.
I installed the backend with 6.0.0 command prompt (“pip install kikit”), then updated KiCad to 6.0.1 and installed the GUI with the PCM. It works.
The backend was installed to C:\Users<username>\Documents\KiCad\6.0\3rdparty\Python39\site-packages. The GUI to C:\Users<username>\Documents\KiCad\6.0\3rdparty\plugins\com_github_yaqwsx_kikit.
I can also use the KiCad PCB Editor’s Tools → Scripting Console to import kikit and kikit.plugin and run kikit.plugin.importAllPlugins().
