There were already few topics about this however I do not find solution for my issue.
After Kicad update to version 6.0.4 (where old KiCad 5.1.9 still on PC - should I remove it ?), it seems that RF_tools scripts are not working well. I’m trying to run via_fence and get message:
What is interesing, when I try to install this, from command line I get:
c:\Program Files\KiCad\6.0\bin>pip install pyclipper
Requirement already satisfied: pyclipper in c:\users\admin\appdata\local\programs\python\python37-32\lib\site-packages (1.3.0.post2)
However when trying to install from c:\Program Files\KiCad\bin, I get following:
c:\Program Files\KiCad\bin>pip install pyclipper
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
Collecting pyclipper
Using cached pyclipper-1.3.0.post2.tar.gz (132 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... error
ERROR: Command errored out with exit status 1:
command: 'c:/Program Files/KiCad/bin/python.exe' 'c:\Program Files\KiCad\lib\python2.7\site-packages\pip\_vendor\pep517\_in_process.py' get_requires_for_build_wheel 'c:\users\admin\appdata\local\temp\tmpi9wnvz'
cwd: c:\users\admin\appdata\local\temp\pip-install-he08or\pyclipper
Complete output (4 lines):
Traceback (most recent call last):
File "c:\Program Files\KiCad\lib\python2.7\site-packages\pip\_vendor\pep517\_in_process.py", line 26, in <module>
import compat
ImportError: No module named compat
ERROR: Command errored out with exit status 1: 'c:/Program Files/KiCad/bin/python.exe' 'c:\Program Files\KiCad\lib\python2.7\site-packages\pip\_vendor\pep517\_in_process.py' get_requires_for_build_wheel 'c:\users\admin\appdata\local\temp\tmpi9wnvz' Check the logs for full command output.
Maybe the script is recalling wrong path, however where and how to change it ?
Thanks in advance
