[SOLVED] Howto change properties on multiple objects
having multiple objects (e.g. pads) and i want to change a specific property of all of them in one command.
For one object: Select object, right click properties (Eigenschaften) and change the value e.g. net name.
When selecting several similar objects, there is no properties on right click.
E.G. changing net name from ‘not connected’ to ‘GND’ is not possible for all selected items?
wolfgam
Welcome to the forum!
You did not reveal your version, but in 7 there is a property manager, enabled by view->property manager:
Not sure if that meets your needs, but anyways…
This is what i was looking for.
Thank you!
