The following Error is issued if I try to load the file “goboard-main.kicad_pcb” with the StepUp workbench in FreeCAD:
10:40:17 opening /home/bernd/Dokumente/Projekte/Tastatur/goboard/hardware/main/goboard-main.kicad_pcb
10:40:17 my file path /home/bernd/Dokumente/Projekte/Tastatur/goboard/hardware/main
10:40:17 py3
10:40:17 Running the Python command 'ksuToolsOpenBoard' failed:
Traceback (most recent call last):
File "/home/bernd/.FreeCAD/Mod/kicadStepUpMod/kicadStepUpCMD.py", line 656, in Activated
kicadStepUptools.onLoadBoard()
File "/home/bernd/.FreeCAD/Mod/kicadStepUpMod/kicadStepUptools.py", line 7744, in onLoadBoard
mypcb = KicadPCB.load(name) #test parser
File "/home/bernd/.FreeCAD/Mod/kicadStepUpMod/kicadStepUptools.py", line 1673, in load
return KicadPCB(parseSexp(f.read().decode('utf8').replace(u'\\"',u'_'))) # maui replacing \" with _ to avoid wrong parsing test py3
File "/home/bernd/.FreeCAD/Mod/kicadStepUpMod/kicadStepUptools.py", line 1530, in parseSexp
assert stack, "Trouble with nesting of brackets"
The project can be found here: https://github.com/BerndGottschlag/goboard
The issue is present in all commits I tested. The newest commit at the time of writing is a253129a.
A few things to note:
- KiCad does not show any errors when opening the PCB and I can see the PCB in the 3D viewer.
- The PCB is currently a work-in-progress. Many footprint assignments and traces are still missing.
- Only the main board (hardware/main) has this problem, the numpad (hardware/numpad) can be loaded in FreeCAD.
- The only 3D-model I added (the USB-C jack) does not seem to be the cause of the problem. When I add it to the numpad the problem does not occur.
- If I remove all footprints from the PCB that are not from the standard library and not present on the numpad the problem still occurs.
This topic is linked to my problem:
Is there any way I can further troubleshoot the problem (e.g. logfiles)?
Do you have an Idea how to fix this?
Any help is appreciated!
Version Information:
KiCad:
Version: 5.99.0-unknown-r25169-00a99101, debug build
FreeCAD:
OS: Fedora 33 (Workstation Edition) (GNOME/gnome-xorg)
Word size of OS: 64-bit
Word size of FreeCAD: 64-bit
Version: 0.19.Unknown
Build type: Unknown
Python version: 3.9.0
Qt version: 5.15.1
Coin version: 4.0.0a
OCC version: 7.5.0
Locale: German/Germany (de_DE)
sudo dnf info freecad
gives the following info:
Release : 0.3.20201125gita50ae33557.fc33.2
Source : freecad-0.19-0.3.20201125gita50ae33557.fc33.2.src.rpm
Operating System:
Name: Fedora 33 (Workstation Edition)
64-bit
GNOME-Version: 3.38.2
Display manager: X11
