Hi, as of today when I’m in a schematic and go to assign footprints I get this pop-up:
Could I get some help?
Disk corruption problems? What’s in fp-lib-table? Does it look like a proper S-expression file or is it garbage?
Which kicad-version?
(for v7-nightly: there was a bug affecting the fp-lib-table/sym-lib-table-files. A update will probably help)
Went for a new install as I’m up against the clock and don’t have time for troubleshooting, but now despite changing all my paths non of my libs are showing up, custom one I slapped into the folders, and even the ones downloaded via the plugin manager? So I only have access to the default footprint and symbols.
Did you try loading your Personal libraries one at a time using File / Add Library in your Symbol editor and Footprint editor?
I did, but from the wrong drive
All re installed and working now.
