(solved) Filled zone not filling
I have a project where filled zones don’t appear to work. I deleted the .kicad_pcb file and started afresh, but filled zones still did not fill.
I started a new test project and filled zones work as expected.
I’m assuming it’s not a bug, and would rather know what I’ve done wrong to avoid it next time, so… any clues?
Kicad 7.0.2 if that helps.
RpiHat.zip (557.2 KB)
It is filled, you just have zone outline only mode enabled. Click this
You will likely have to tweak zone spoke settings if you want to actually connect to tiny pins.
Ahahaha. Fantastic.
Thank you, I was looking in the preferences menu but missed that icon
