Default netclasse has clearance of 0.1 mm
VBAT netclass has clearance of 0.5 mm
If I define a zone attached to GND I would expect the fill zone to respect the defined netclass.
Even if I give the fill zone a clearance of 0.5 it doesn’t respect that, it always fill until it is 0.1 mm from an other net.
Fill zone priority = 0
Do you have additional custom rules in use?
Are you sure that VBAT has the correct netclass assigned? (click the via – look at statusbar: “resolved netclass”).
Instead of guessing it’s always much easier if you attach the project (as zipped archive from kicad manager–>File–>archive project). You could also delete all unnecessary symbols/footprints except the relevant vias/tracks if there is some confidential content.
Thanks, it is solved.
I had an old custom rule in use, forgot about that one. I still don’t understand why that rule had an impact on the fill zone, as far as I understand it should only apply within the courtyard of U701 and definitely not on inner layers. But it was the first time I even used a custom rule so probably I messed up.
only guessing (I’m no expert regarding the rule-system, I use only simple netclass-rules): the clearance applies to this rule because the zone itself is probably intersecting (flowing through) U701.
