I sometimes construct relative large PCBs with 2 or 3 different resistor values. For these particular boards I am more interested in values than component numbers as it helps me solder faster.
The value is always in the F Fab layer by default. The first things I always turn off are the fabrication layers.
Is there an easier method to get these values in the front silk layer than manually doing that clicking work.
I can find the lines in the board files using regular expressions in VScode. And replace the texts bij hand. I do not yet know how I can let the regular expression ‘scipt’ can do this for me. I believe that should be possible.
\(fp_text value ".*R"
Besides such a script are there mores options in pcbnew to get resistor/capacitor values in the front silk layer? I am guessing that this ‘inconvenience’ comes from the component libary and therefor cannot be easily fixed like the the default text size?
