Hi!
Trying to use the MCP73833. Power in and power out are shared by two pins, respectively.
Given that the footprint and the symbol need to have the same pin numbers and order, I though in making two pins for each, place them on top of each other and hide one of them. The problem I’m having is that both pin 9 and 10 output power, and they are internally connected. The DRC complains because two output pins can’t be connected to each other. How do I solve this? By changing the type of pin of one of the output pins?
