[SOLVED] Disabling zoom change in PCB editor
How do I achieve that the display (zoom) in the PCB editor does not change if I select a symbol in the schematic editor? Otherwise, how do I force the PCB editor not to change the zoom.
Disable: Preferences / Preferences/ PCB Editor / Display Options / Cross-probing / Zoom to fit cross-probed items
(Note: there is a similar setting in preferences for the Schematic Editor, for cross probing the other way around).
Thank you for your reply - solved.
