[SOLVED] Could not use OpenGL falling back to software rendering
I have install KiCAD 7.0 on a virtual windows machine and I have the below information message that I would like to remove (this perfectly fine I was not expecting something else with a virtual machine, but I have this message each time I am opening a kiCAD window):
“Could not use OpenGL, falling back to software rendering”
This should set it for you . . .
But software rendering is a severe slowdown. So the question remains why OpenGL does not work in your VM.
It is not uncommon for VMs to fail at OpenGL. Even the Microsoft Hyper-V VMs don’t support OpenGL beyond the ancient OpenGL 1.1, meanwhile we need a newer OpenGL that isn’t 25 years old.
Thanks for the tip, it seems to work (I have not seen the message)
Then I support other message on OpenGL obsolescence
