I wanted to make a separate PCB to act as front end. So I wanted to add mousebites to connect the main board and it’s front panel.
This leads to this one small inconvenient problem. I always use rectangles to make the outer lines. When I add the mouse bites I am forced to redraw the rectangles using lines.
For this design in particular I wont be using mousebites afteral. It will ruin the front panel for sure. But for other designs I would not mind if we can convert rectangles into lines to solve this problem.
Regards,
Bas
