Hi all!
I have a project where I need to change the track clearance for some specific nets. Setting the clearance in a custom net class did not help. Please see below:
Can you please give any guidance?
Thanks
Hi all!
Thanks
additional note: always add a small note which kicad version you use.
note2: the picture is not really self-explanatory. I assumed that you wanted to draw that small track and got clearance errors.
What is your board minimum clearance? Netclass clearances cannot reduce the clearance below the minimum clearance, they can only increase the clearance from there.
Also, what is the clearance set for that copper zone (in its properties)?
What I want to achieve is a full connection between C1 and GND plane
Than additional to my above mentioned things (board clearance constraint, GND netclass clearance) maybe you have to look into the zone settings of the GND plane.
Values for zone clearance and zone minimum width may important.
Select that track and the zone and run Inspect > Clearance Resolution
I suspect GND belongs to netclass default → therefore a gap of 0,2mm between GND and your track. (edit: yes, your next picture shows it)
Why Default class appear there?
If you have two different netclasses the bigger value is taken.
Yup that was it.
Thank you all!!
Forgot about the GND…
