[SOLVED] Cannot load schematics
Hi All,
I’d like to report an issue here: I’m not able to open a schematic because Kicad tells me that schematic was created with a more recent version, but indeed I installed the last Kicad 7.0.6.
Application: KiCad x64 on x64
Version: 7.0.6, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1-DEV Schannel zlib/1.2.13
Date: Jul 6 2023 04:56:45
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.81.0
OCC: 7.6.3
Curl: 7.88.1-DEV
ngspice: 40
KICAD_SPICE=ON
I got the project here:
demos/pic_programmer · master · KiCad / KiCad Source Code / kicad · GitLab
Thank in advance for help
GB
Open the schematic file with a text editor.
The schematic may have been done with a nightly version, 7.99 the future v8.0
Hello @GB619
That link you show is to a correction, by a developer, in the source code for a demo project.
For the real project, open Kicad, go to File > Demo Project then select that project from the list.
Hello @jmk
Thank you, I thought that it was the repository for real demo projects.
Thanks!
Regards
GB619
It is the repository, but you probably looked at Master, when you should have looked at the 7.0 branch
Yes, has “master” in it’s URI string, so that seems logical.
It is also a bit of a weird demo project. It’s not a particularly well designed PCB.
It’s a double sided PCB, but most tracks are on the underside and completely unnecessary cut the GND plane to pieces. It’s also a quite big PCB that is mostly empty. It’s likely from one of Charras’ students and made 20+ years ago.
@GB619
For some more complex (and also well designed) KiCad projects, have a look at:
Hello @paulvdh,
thanks for the tip!
I see many interesting projects there.
Regards
