You have probably added this library name at some time in the past (maybe an experiment?) to either your global library table or one of the projects.
It should be listed in the menu under Preferences / Manage Symbol Libraries.
So select the right tab page (Global or Project specific) then select the line with that library name and click on the garbage bin to delete that library entry from the library table.
