Default is green and I would like to change it - is it possible?
J
J
Yes, you can do it in the board stackup section . . .
Or directly in the 3D viewer preferences . . .
Thanks a lot, already managed ![]()
I can’t get this to work. I tried changing the F.Mask and B.Mask colours to Red like you showed, but nothing changes in the 3D view.
My 3D viewer preferences doesn’t have a Colors subdialogue. It looks like this:
My version info. From the date of the start of this topic, version you were showing would be v7. Was the Colors option removed from 3D viewer preferences?
Version: 8.0.6, release build
wxWidgets 3.2.6
FreeType 2.10.4
HarfBuzz 8.3.0
FontConfig 2.14.2
libcurl/8.6.0 OpenSSL/3.1.4 zlib/1.2.13 brotli/1.0.7 zstd/1.5.5 libidn2/2.2.0 libpsl/0.20.1 libssh/0.9.8/openssl/zlib nghttp2/1.40.0 OpenLDAP/2.4.46
Platform: openSUSE Leap 15.6, 64 bit, Little endian, wxGTK, X11, KDE, x11
OpenGL: NVIDIA Corporation, NVIDIA GeForce GT 710/PCIe/SSE2, 4.6.0 NVIDIA 470.256.02
Date: Nov 10 2024 12:00:00
wxWidgets: 3.2.6 (wchar_t,STL containers) GTK+ 3.24
Boost: 1.75.0
OCC: 7.7.0
Curl: 8.6.0
ngspice: 43
Compiler: GCC 11.3.0 with C++ ABI 1016
Have you set this checkbox in the 3D viewer?
I don’t have that checkbox in my 3D viewer preferences. Here are the other 2 subdialogues in addition to the one already posted:
Oops, it’s not a preference, it’s in the Appearances panel. That works. Now I can see the blue mask that I usually order. Thanks!
That was probably from when I was on V7.x.x it was approx 18 months ago ![]()
