Hi folks! This is my first message so I kindly welcome you all )
I’m trying to build KiCad from sources in order to get the latest 5th version. I’m far from being expert in building from sources (escpecially with CMake) so I need an advice. Could anyone to help me resolve the missing OpenMP_* flags and shed light on why they are needed?
Here is the output after cmake was executed:
-- Kicad install dir: </usr/local>
-- Could NOT find OpenMP_C (missing: OpenMP_C_FLAGS OpenMP_C_LIB_NAMES)
-- Could NOT find OpenMP_CXX (missing: OpenMP_CXX_FLAGS OpenMP_CXX_LIB_NAMES)
-- Could NOT find OpenMP (missing: OpenMP_C_FOUND OpenMP_CXX_FOUND)
-- Check for installed GLEW -- found
... [everything else seems ok]
-- Configuring done
-- Generating done
-- Build files have been written to: /home/timur/Desktop/kicad/build
I don’t even know if they somehow impact the program itself, but the building process was certainly slooow!
I have already posted the message alike in the Void forum but get no response so I hope to get it here
I use Void Linux as my primary system. I’ve checked if suitable libraries are installed ([*] means installed):
xbps-query -s[earch locally] openmp
[*] libgomp-7.3.0_3 The GNU C Compiler - OpenMP v4.0 library
[*] libgomp-devel-7.3.0_3 The GNU C Compiler - OpenMP v4.0 library - development files
As a reference for resolving dependencies I used this and this.
Just in case, how I did it:
git clone https://git.launchpad.net/kicad
cd kicad
git checkout 5.0.0-rc2
mkdir build && cd build
sudo xbps-install -S python wxWidgets-devel wxPython-devel python-devel glew-devel cairo-devel glm libcurl-devel boost-devel oce-devel swig libgomp-devel
vi build.sh:
#!/bin/bash
export CXXFLAGS="$(wx-config --cxxflags)"
cmake -DCMAKE_C_COMPILER=clang \
-DCMAKE_CXX_COMPILER=clang++ \
-DKICAD_SPICE=ON \
-DKICAD_SKIP_BOOST=ON \
-DKICAD_SCRIPTING=ON \
-DKICAD_SCRIPTING_MODULES=ON \
-DKICAD_SCRIPTING_WXPYTHON=ON \
-DPYTHON_SITE_PACKAGE_PATH=/usr/lib/python2.7/site-packages -DPYTHON_DEST=/usr/lib/python2.7/site-packages \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_INSTALL_PREFIX:PATH=/usr \
./build.sh
... (log is above)
make -j8
sudo make install
kicad
# program runs ok
