[SOLVED] Board edge clearance violation?
I’ve got a small PCB laid out and getting DRC errors:
Error: Board edge clearance violation
Line on Edge.Cuts
From the error is it complaining that the component is too close to the edge of the PCB? Pad 4 of J1 is on a edge cut?
Screenshot from 2022-06-04 19-35-54
Screenshot from 2022-06-04 19-36-47
Looks fine to me unless I’m missing something?
Where are your Edge.Cuts lines?
The error is “Line on Edge.Cuts”. I’m not exactly sure how to interpret that.
What if you disable all layer except Edge.Cuts, do you see something strange then?
In my understanding the error means there is a line on edge.cuts other than a polygon (open or closed).
Thanks, you pointed me the right direction.
I moved the connector a little to the left and there was a dot underneath it (edge.cut)
Removed this and it’s fixed the problem.
Screenshot from 2022-06-04 20-07-05
