[SOLVED] At that the same time all layer is existed single layer (like silkscreen) in the gerber
Hello All,
I am using KiCAD 7.0. When I plot the gerber, i realized very strange thing. I 've checked kicad documents and other source in google. But I couldn’t find any thing about this point.
The gerber file in fact showed all layer where in the silkscreen at the same time.
When I check the other layer like mask layer; that acted like previous(silkscreen), too; all layer seem single layer in gerber.
I couldn’t solve this problem. Do you have any enperience about it? Or Do you have any suggestion?
Thank you!
Gamze
PCB Editor / File / Fabrication Outputs / Gerber And then turn off the checkbox for plotting the silkscreen on all layers.
I understood that each gerber file contained all layers. So not only turn off silkscreen checkbox, but turn off all checkboxes in ‘Plot on All Layers’ box.
Thanks Paul!
It does work. I get used Orcad/Allegro. Nowadays, I try to adapt to KiCAD.
KiCAD Community power is amazing. Thanks for reply again.
