Recently, when flipping a board in the 3D viewer, there is a sequence
- original board
- board rotated 180°
- board flipped
- flipped board rotated 180°
- restart
Is this new or simply a bug?
Looks good in:
Version: 7.99.0-unknown-ace7cbddfe~172~ubuntu22.04.1, release build
Date: Oct 15 2023 03:18:17
3D view with “f” just flips the board. Same result as rotating the board 18 times with the Y icon. (From my way of seeing things, Y rotation and Z rotation are interchanged)
I used the icon
Same result as F. It rotates 180 degrees around the Z axis.
Ok, thx. Anyways, here’s the video, just in case someone else wants to see that.
This is not what happens in my today’s copy. It works as expected.
I happen to have 7.0.7rc1 and probably yesterday’s 7.99, both work correctly. I didn’t find any Preferences which logically might affect this.
With an old board 7.0.8 does not show the effect, 7.99 does. I cannot open my recent 7.99 boards with 7.0.8 for obvious reasons.
Thanks for checking anyways.
I just recompiled the latest 7.99 code, no problem. Try again with the next nightly build if you use nightly builds.
Myteriously solved by today’s nighly, although I cannot see any commits that might be related.
Anyways…
This was related to a change in quaternion data layout in glm library, which vcpkg had updated to an unreleased version. The glm version has been pinned to the working one.
