For the past 3h I’ve been reading all posts and watching tutorials about getting the 3d shapes for footprints to show up - and all I get is a bare PCB no matter what I do.
I’ve verified that the 3d models are installed (/usr/share/kicad/modules/packages3d), the shape is correctly set in the footprint properties and I made sure that all “3D model visibility” in the 3d viewer preferences are checked - still no dice.
Even when I use “Add 3D Shape” in the footprint properties the preview window stays blank (black), regardless of which shape (wrl or step) I select. Same if I hit “Alt 3” in the footprint editor, no 3d shapes other than the pcb.
I opened some of the 3d shapes files with FreeCAD and they do contain the proper shape. I’m at the end of my wits - any help is much appreciated!
Edit: added version info -----------------------------------------------------------------
Application: kicad
Version: 5.0.0-rc3+dfsg1-1, release build
wxWidgets 3.0.4
libcurl/7.60.0 OpenSSL/1.1.0h zlib/1.2.11 libidn2/2.0.4 libpsl/0.20.2 (+libidn2/2.0.4) libssh2/1.8.0 nghttp2/1.32.0 librtmp/2.3
Platform: Linux 4.16.0-2-amd64 x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.62.0
Curl: 7.60.0
Compiler: GCC 7.3.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=OFF
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=OFF
