I just wanted to share a fix to building the latest code and getting the error about wxWidgets
Could NOT find wxWidgets: Found unsuitable version "2.8.12", but required
is at least "3.0.0" (found
The problem from what I can tell is in “./CMakeModules/FindwxWidgets.cmake” line ~860.
find_file(_filename wx/version.h PATHS ${wxWidgets_INCLUDE_DIRS} NO_DEFAULT_PATH)
I printed “wxWidgets_INCLUDE_DIRS” and verifed that it was pointing to 3.0 include directories. But for some reason find_file was still finding the 2.8 wxWidgets which I also have installed.
The solution (not a good solution but it works) is to manually set “_filename” like this
set(_filename "/usr/include/wx-3.0-unofficial/wx/version.h")
Hope this helps until a more permanent fix gets put in.
AdShea
November 13, 2014, 5:46pm
2
I haven’t had much luck in finding where to submit bug-reports, but the wx-config script supports a --version=3.0 flag which should be possible to stuff into cmake.
The bug reporter can be accessed from the launchpad : https://bugs.launchpad.net/kicad/+filebug
fchyan
November 14, 2014, 11:29pm
4
Alternatively if you don’t want to modify the .cmake file:
Follow the manual build instructions here, except at the cmake …/ part.
http://www.kicad.org/display/DEV/Building+KiCad+on+Linux
First install wxWidgets 3.0.0:
sudo apt-get install libwxbase3.0-dev libwxgtk3.0-dev
and then replace cmake …/ with the following:
cmake ../ -DwxWidgets_CONFIG_EXECUTABLE='/usr/bin/wx-config'
Is wxWidgets 3 already available in 14.04 repositories? It wasn’t the case yet recently.
For anyone getting this error using kicad-install.sh, make sure you are not using an old kicad-install.sh
Get the latest here:
I can confirm that for me it started working again when using the latest kicad-install.sh and running
./kicad-install.sh --remove-sources
prior to attempting a build
Slawek
April 1, 2015, 4:54pm
8
I’ve had to do this a few times. I run Debian Jessie (8.0) with 3.16 kernel. This is what I have to do to resolve this issue.
Remove remaining instances of wx2.8
sudo apt-get remove wx2.8-headers
You may have more packages, so type in wx2.8 and use tab completion
Purge remaining instances of wx2.8
List the installed instances of wx
dpkg -l | grep wx
Uninstall the results that show up with “2.8” one by one with this command (you will get dependency errors if you don’t do it in a particular order)
sudo dpkg --purge python-wxgtk2.8
sudo dpkg --purge libwxgtk2.8-0:amd64
sudo dpkg --purge libwxbase2.8-0:amd64
Install/re-install wx3.0 packages
sudo apt-get install --reinstall libwxbase3.0-dev libwxgtk3.0-dev
Link wx-2.8 folder to wx-3.0
sudo ln -s /usr/include/wx-3.0/ /usr/include/wx-2.8
This step is necessary due to what seems to be as a result of what I think is a hard coded directory in the kicad source.
Compile and go get a snack
