Solder paste relative clearance
Hello
I ordered some PCBs from JLC along with a stencil. I populated the board manually after applying T4 paste with the stencil and reflowed in a small oven. The stencil has a thickness of 0.12 mm.
I set -5% solder paste relative clearance in board setup but the results were not that great. I had to rework a lot of bridges on an LQFP-48 part with .5 mm pitch. The remainder of the board are parts with a far coarser pitch (SOT-223, SOIC-16W, 0805) and those reflowed flawlessly. The rework was easy to do but I am convinced that I can improve my process.
Do you recommend reducing the relative paste clearance further? To what number? Is the percentage I enter in “board setup” relative to the area/volume or to the length of the edges of the pad? Also, I tried to set it to -50% to answer that and then the paste aperture completely vanishes, which has me confused.
I am happy for any advice. Thank you and best regards!
Matt
KiCad Version Info:
Version: 9.0.4-1.fc42, release build
wxWidgets 3.2.8
FreeType 2.13.3
HarfBuzz 10.4.0
FontConfig 2.16.0
libcurl/8.11.1 OpenSSL/3.2.4 zlib/1.3.1.zlib-ng brotli/1.1.0 libidn2/2.3.8 libpsl/0.21.5 libssh/0.11.2/openssl/zlib nghttp2/1.64.0 OpenLDAP/2.6.10
Platform: Fedora Linux 42 (Workstation Edition), 64 bit, Little endian, wxGTK, X11, gnome, wayland
OpenGL: Intel, Mesa Intel(R) Iris(R) Xe Graphics (RPL-U), 4.6 (Compatibility Profile) Mesa 25.1.7
Date: Aug 18 2025 00:00:00
Boost: 1.83.0
OCC: 7.8.1
Curl: 8.11.1
ngspice: 44.2
Compiler: GCC 15.2.1 with C++ ABI 1020
KICAD_IPC_API=ON
Locale:
Lang: en_US
Enc: UTF-8
Num: 1’234.5
How did you place the LQFP? Any slight misalignment will lead to solder bridging.
Thank you for your response. We have one of those electronic suction machine thingies that pull a slight vacuum when you push a pedal and with that, you can pick up the part and drop it in the appropriate place. That said i guess the answer to your question is “I did it manually” and any potential misalignment is on me. I thought I was pretty careful when placing the part but then again, I have little experience with this process.
I did some research before posting here and bridges on fine-pitched part are primarily attributed to too much paste (see, e.g. here, although this post also claims that 0.5 mm QFP is impossible without stencil and I have done that in the past and it was easy… Then again this seems to be common advice, see e.g. here and here [I am not allowed to add another link as new forum user] but of course, too much paste is not the only reason for bridges. Still it somehow makes sense for me to start there.)
I am still confused about the -50% relative aperture thing that shrinks the aperture down to zero…
It’s all of the above, plus the size of the solder balls and the thickness of the flux.
If you plan on doing a lot of these types of assemblies, you should make a test board with various sized openings, and see which works best for your process.
Note that even professionals with finely-tuned processes get the occasional solder bridge on QFPs.
And the age of the solder paste and how it has been stored and how long it has been left on the board, etc, etc
