Solder Mask expansion issue
I am using a fiducial from the KiCad footprint library however I have noticed that when flipping the component to the bottom side the solder mask expansion is not kept. Is this a bug or do I need some specific setting? I exported the Gerber and checked separately and it is not just a display in kicad issue.
Anyone encountered this before?
I suspect that the likelyhood of precise answers would go up if you were to give a little more information.
Perhaps specify which fiducial footprint, perhaps a screenshot or two to illustrate what happens?
(Just my spontaneous €0.02…)
This is a known issue with kicad v9.0.0. Should be fixed already.: Clearance override "Solder mask expansion" not override сlearance on B.Mask layer for NPTH, Mechanical pad type (#20053) · Issues · KiCad / KiCad Source Code / kicad · GitLab
You may try to install the latest v9.0-testing version.
note: For a useful output (==answer) it’s always good to provide good input. For most questions this requires to write at least the used kicad version.
In this special case I have (by chance) given a similar answer already yesterday, so I have just guessed your kicad version.
It’s any fiducial hence why I didn’t specify any. Yes, the issue identified by @mf_ibfeew is the correct one. Version of kicad is 9.0
