When adding a filled zone (GND plane), the thermal relief gap on the GND pad of the Rounded Solder Jumper (SolderJumper-2_P1.3mm_Open_RoundedPad1.0x1.5mm) doesn’t seem to be honoured:
Switch to the non Rounded Solder Jumper (SolderJumper-2_P1.3mm_Open_Pad1.0x1.5mm), and it works ok:
This is on the latest 9.0.1 build for Windows x64. I’ve also tried the latest Nightly, but it does the same.
No overrides are applied to the footprints. Is this a known issue, or am I doing something wrong?
