SOD-523 footprint doesn't always show up in Cvpcb (fixed)
I’m adding a few components, one is an MM5Z5V1, a Zener in SOD-523(F) and that’s fine, I select the footprint in schematic and shows in Cvpcb (though no 3D, but that’s another matter).
Then I add a BAT54X, a Schottky, still a SOD-523, schematic fills the proper footprint name as well, still as “Diodes_SMD:SOD-523”, but hey: if select the part in Cvpcb no footprint is shown. Curious enough, there’s no available selection on right side panel for “Diodes_SMD:SOD-523”, as if the schematic “D_Schottky” symbol is somewhat different from the “ZENER” one…
Any idea?
Note: if I fill the footprint from schematic, everything works and the netlist for PCB is prepared correctly
EDIT: can I say “I am dumb and didn’t notice the active filter toolbar?” :smiley: Yes, problem is non-existent, just had to fix filter selection
