I’m working on a circuit where I want to use a hexadecimal rotary switch to select between four different capacitors. The idea is to manually switch between various capacitance values and measure the resulting power consumption at the output. I want a input signal from a IC(PIC16F690) to the switch which i will be measuring on but after the capacitors.
So your KiCAD question is?
How do I insert a high side current sensor in KiCad?
The smart solution to this problem post is to close it.
