When I read the Net file, the size of the References, Text and Values are H=1mm W=1mm
I spend hours to change it manually. Is there a way to change everything at once?
I have tried with Dimensions> Text and Drawings but not works to me.
Best regards
Text-editor or scripting will definitely work.
Or you setup your own library with the text sizes set to what you prefer.
pedro
3
Menu Edit -> Set Footprint Field Sizes
Thank you for the tip! , I changed all from file.kicad_pcb with gedit.
(effects (font (size 1 1) (thickness 0.05)))
to
(effects (font (size 0.2 0.2) (thickness 0.05)))
Best regards
Thanks Pedro, I had changed the values in ‘Set Footprint Field Sizes’ but I haven’t selected the checkboxs.
Best regards
system
Closed
6
