Hi
Is it possible to create singlesided print with all the through holes non platet, just as if the print were home etch?
If i create a solder wire pad on the back copper layer(same layer as tracks), and select the NPTH pad-type, with only the B.Mask checked, it seems as there is not a clear hole all the way trough the print. In 3D view it looks like there is a layer of soldermask covering the hole? Maybe its just the 3D rendering thats playing tricks, but i dont want to take any risk ordering a print with no drilled holes in it.
Does anyone has a solution to this?
