Hi everyone!
Im very new to ngspice and using it in KiCad, so please forgive me if im being stupid.
I was experimenting with a simple differential amplifier that I plan to use for measuring temperature.
When i set R5 to 1k, the simulation runs perfectly. The problem arises when i cange the value to any other value. At first I thought it had to do with “uneven” numbers like 1.3k, but with anything above 1.1k I do not get any results.
Error Message:
“doAnalyses: OP: Timestep too small; trouble with xu1.xi_nn:dvnf-instance d.xu1.xi_nn.d1
run simulation(s) aborted”
If i need to provide the original project for you to help, please tell me how its done.
This is my first post in a forum of any sort.
Thank you very much for your help!
Application: KiCad x64 on x64
Version: 9.0.4, release build
wxWidgets 3.2.8
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
Platform: Windows 11 (Erzeugungsversion 26100), 64-bit Edition, 64 bit, Little endian, wxMSW
OpenGL: NVIDIA Corporation, NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2, 4.6.0 NVIDIA 572.83
Date: Aug 18 2025 00:41:45
Boost: 1.88.0
OCC: 7.9.1
Curl: 8.13.0-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: de_DE
Enc: UTF-8
Num: 1.234,5
