The simulation plot doesn’t match yours above. The first 555 isn’t outputting a delayed pulse. Also the netlist outputted by KiCAD 7.0 looks and simulates differently than the one supplied in the example.
I detailed what I found over at the ngspice forum.
This is an oscillator circuit with all its quirks, especially the start-up of the oscillator depends on tiny details of the simulation setup. I have added a start-up pulse to allow early starting of the oscillation. And due to its using CMOS it is inevitable to not set ngbehavior to ps.
These are Eeschema error messages. The automatic translation to KiCad 8 does not do correctly, as the simulator interface has changed a lot. I have started doing the translation manually for a few examples, as listed here More simulation examples for KiCad/Eeschema/ngspice - #4 by holger. I will add to this list as time allows. You are welcome to support me with this task.
I am available to do testing. I will look at the changes you made but I already “updated” the examples with the ones you recently posted but some like the “new” Q17 don’t work with KiCad 8 either. I upgraded to KiCad 8 because I couldn’t open these files with KiCad 7.0.10. Now I have lot’s of files that don’t work in 8 and won’t open with 7.0.10. I’m looking for a newer version of “7” that works with your newer files but I downloaded [kicad-7.0-testing_7.0.10.171] and Q17 still won’t load.
The files in this thread are made with KiCad6 and all are tested with KiCad 6.0.2 or 6.0.10.
They may or may not run with KiCad 7 (not tested!) and several will not run with KiCad8, as there have been a lot of changes.
The examples shown in More simulation examples for KiCad/Eeschema/ngspice will not open in KiCad6 or KiCad7, as they are made with KiCad 7.99 or recent KiCad8RC2. They will open only in the latest nightly, which is moving towards KiCad8.
EDIT: Indeed Q17 does not run with the current nighly. I have uploaded a new version of this project.
I found three “versions” of Dual-NMOS-Amp-VDMOS. Only the one I attached opens and works with KiCad 7.
To get it to partially to work with KiCad 8 I have to delete the “thermal” parameter from M1/M2. Of course then the thermal model doesn’t work.
Can you explain why Sim pins for M1/M2 has duplicate entries?
1=D 1=D 2=G 2=G 3=S 3=S 4=TJ 4=TJ 5=TCASE 5=TCASE
Is it possible to “fool” KiCad to open newer version files by altering the header in the sch file? I do this for other SW. I did notice version 8 sch files have a lot of differences from version 6/7.
I have already published a modifies F5 to the KiCad8 example page.
You have to modify the model subcircuits. The .param lines from within the subcircuit have to be shifted to the top, to the .subckt line itself. In ngspice both syntaxes are eqivalent, new Escheema wants them to be on the .subckt line.
I’d love to see instructive style S-Parameter Analysis examples for KiCad8 RC2 (and above) SPICE simulation. I pulled down the S-Parameter example above and spent ½ day trying to run it under Windows11KiCad8 with NGSPICE42. I know next to nothing about S-Parameter analysis except a very high level description. I’m building digital circuits which run at 2+GHz and I am wondering what “new to KiCad” tools are available to ensure, it will work (IBIS modeling?), Signal integrity (IBIS or S-Parameters?), or how much radiation I might be generating (S-parameters?).
I’m excited that I finally got my old tried and true 555-Timer CAE evaluation circuit simulating. It took KiCad8 for me to finally see that my schematic pins weren’t matching my simulation pins, which is what finally make it work.
In KiCad8 I’d love to see parameter verification for things like BJT model parameters. It took me a while to realize the errors I was seeing were from parameters Gummel-Poon and VBIC simulation models don’t support. It would be nice to have a more concise message saying “xtb=1.5” not supported (it is, but just an example), so I can remove it and find some other workaround to get my simulation running.
Anyway, amazing work by both the KiCad and NgSpice teams, and yes, I find this exciting!
This is truly and invaluable KiCAD ngspice thread on the forum. I read it from start to finish, plus some of the side “links”. I’ve recently begun learning to use Spice simulations within KiCAD V8.0.8 and ngspice 44 after watching a number of YouTube videos on getting started with LTSpice AND KiCAD 8’s ngspice integration. I’m using Win11 Pro having recently switched from 10 Pro since the last decade or more.
@holger, thanks for your examples and answering reader questions.
My question: Is there a preferred location for Spice model (.mod, etc.) files within KiCAD 8.0.8? Thus far I’ve only download and used the TI TL084 ngspice model and associated it to a KiCAD (single) op amp symbol used in my differential LPF op amp analysis schematic.
