Simple plugin to export IPC356 net list
I needed a way to export IPC356 format.
The file could be used to recreate ODB++ format by combining this with Gerber files in Valor process Engg.
I managed to recreate a good quality ODB++ by combining the Gerber files and the IPC file.
Feel free to comment on the project.
Sure you can use GenCAD that you can export from KiCAD directly… That is another way of doing the same thing.
Project github:
Thanks.
Mariwan
Cool project.
In your readme you should mention to put the plugin in the folder that is opened through
Tools → External plugins → Open Plugin Directory
in the pcb editor.
Works on all platforms and also points to the correct directory for user plugins. One you suggest currently is for plugins from the plugin manager.
Done . Thanks for your help
