Silkscreen Table is not shown in 3D view
Hey everyone,
I’m currently facing the issue, that my tables, that I created with the ‘Draw Table’ Button in the Layout View, is not shown in the 3D viewer. I checked already that the layer is correct selected for the table and that the silkscreen is also activated in the 3D viewer. I also tried to change the layer to a different one, to see if the table will appear, but also no luck with that.
In the 3D viewers of PCB Manufacturers, I can see the tables.
I’m using KiCad 9.0 release build on Windows 11.
Thanks in advance.
Marco
Looks like a bug . . . have you tried the latest Release build ? or the latest test build ?
If it’s still in the latest test build you should report it as a Bug.
I will install the testbuild and test it.
Thanks.
Ok I tested it with version 9.0.1 release build and here the tables are visible.
So it seems like, that this bug was solved with that version.
