Stackup is correct:
Annoying but not crtitical …
David
I can’t see what the problem is . . . literally !
Could you post an image showing the problem please
In accordance with the prophesies scripture manual:
Layers in the PCB Editor represent physical copper layers on a board, as well as graphical layers used for defining things such as silkscreen, solder mask, and the board edge. There is always one layer that is active in the editor. The active layer is drawn on top of other layers and will be the layer assigned to newly-created objects. The active layer is indicated in the layer selector drop-down box in the top toolbar and is also highlighted in the appearance panel[…]
