I am trying to create my first KiCad board. I placed a B type USB connector at edge of the board. The problem is, silkscreen of connector extends board edge.
Forum doesn’t allow me to upload a picture since I am a new user. (Why ?)
So, anyway, I think you could understand my quesiton. Does it cause any problem with fabrication. I haven’t produced a PCB with that situation. If it may cause problem, how could I remove that silkscreen? Should I create a new part without a silkscreen. Can I disable silkscreen of a module in Pcbnew individually?
That’s a restriction of the forum software intended as spam protection. Once you spent some time in the forum this restriction will automatically be released.
It depends on your manufacturer, some will reject files with excess silk screen, some will just crop it to the board area.
I use a board house that rejects files with silkscreen outside the board area so I developed a technique using the soldermask clipping feature, I mentioned it in another thread:
Just stumbled over the same thing. This is a problem with almost any angled connector that is supposed to be used with e.g. a breadboard or a female header.
It’s not a problem for all the fabricators I’ve used because they will crop any silkscreen outside the board. They are certainly not going to print your silkscreen outside the piece of the large panel that your job has been assigned. Just consider it a warning in case you had some text that you were expecting within the board, which happens now and then when components are moved or rotated.
BTW, notice the original post is 9 years old. Fortunately this is still a valid question.
