Hi, I need to fill a zone with a silk screen polygon, but it covers the pads on the cooper layers. Any idea of what I may be doing wrong? I would post a picture of the settings of the polygon but since Iām new I cant post 2 pictures
When you output your board to Gerbers, you will want to select āSubtract soldermask from silkscreen
ā under the Gerber Options. See this screenshot from v5.0.2_1 (Windows) of the plot requester:
I was unable to find a setting in the 3D viewer that would do the same thing, so as always use your Gerber outputs as a final check, especially for features like this.
Thanks SembuzuruCDE, I will do that then. Thanks!
There is a wishlist bug requesting that: Bug #1807656 ā3D Viewer: wishlist 1/2: add view option to subtra...ā : Bugs : KiCad
