Side Toolbars not fully not visible on lower resolutions PCs
Hi All
version 7.0.8 (below the info data required)
A friend of mine, installed it on a old computer (2016) which is 1366x768
In PCB he can’t see the full right side toolbar. So, he can’t see the following icons:
  • Show vias in outline mode
  • Show tracks in outline mode
  • Show hide the appearance manager
  • Show hide the properties manager
and on the right side bar, he is missing 5 icons:
  • Add a wrapped text item
  • Add an aligned linear dimension
  • Delete clicked items
  • Place origin point for the drill file and components …
  • Interactively measure distance between points
is there anything doable here?
Version: 7.0.8, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1-DEV Schannel zlib/1.2.13
Date: Sep 29 2023 18:44:47
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.81.0
OCC: 7.7.1
Curl: 7.88.1-DEV
ngspice: 41
KICAD_SPICE=ON
The official system requirement states: “Screen resolution of 1280x1024 works but 1920x1080 or higher is recommended”.
He could play with global Preferences–>common–>User interface–>icon scale.
And he should make sure that the windows desktop scale is set to 100% (otherwise he will lose even more screen area).
Thank you so much, I set it up via Team Viewer and it works …
