Show 'actual clearance' for same-net pads/traces in interface
Hey everyone,
I did a quick search to see if there’s already a similar topic, but only found old ones that don’t quite match.
The current state:
When I select two pads from different nets, it shows me the resolved clearance, as well as the actual clearance. When I select two pads on the same net, there is neither.
The problem:
No resolved clearance or clearance being 0mm in the same net makes sense to me. But I need know the actual clearance between any two selected pads/tracks, no matter if it’s on the same net or not. Currently I have to check it manually with the measure tool and even on a simple board that can be quite tedious and time consuming to be precise.
→ Is there a quick way to do this in the current version of KiCad 9? Am I missing something?
To my understanding, the calculation in the background would be the same, no matter if same net or different. It’s just the minimum distance between the two selected polygons.
→ Would it be a viable feature request to just include the actual clearance in the bottom bar, like two different net parts already have?
Thanks for your help!
Example of current state:
Application: KiCad x64 on x64
Version: 9.0.2, release build
	wxWidgets 3.2.6
	FreeType 2.13.3
	HarfBuzz 10.2.0
	FontConfig 2.15.0
	libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: ATI Technologies Inc., AMD Radeon (TM) Graphics, 4.6.0 Compatibility Profile Context 23.19.10.01.240125
	Date: May  7 2025 02:29:49
	Boost: 1.86.0
	OCC: 7.8.1
	Curl: 8.11.1-DEV
	ngspice: 44
	KICAD_IPC_API=ON
Locale:
	Lang: en_US
	Enc: UTF-8
	Num: 1,234.5
You can file an issue in the KiCad gitlab issue tracker for the “physical clearance” (i.e. same-net clearance).
See Feature Request: Show ‘actual clearance’ for same-net pads/tracks in pcbnew interface (#21261) · Issue · kicad/code/kicad for solution.
