Very new to this so hope I’m explaining my problem correctly.
I have a project that uses both slide and rotary potentiometers (both types 10k), my issue is their pins are reversed. Slides work from pin 1 to pin 3 but the rotaries pin 3 to pin 1.
I’ve customised the footprints with graphics and changed alignment (so they’re specific to the project) but I’ve matched the pin assignment from the relevant datasheets.
Is it better (or just less confusing to read) to have all the schematic symbols flow from 1 > 3 and have footprints that don’t match the component datasheet. Or have the symbols flipped on the schematic and annotate with an explanation as to why?
Here’s what I’d done and also what I should do in future. Datasheet wins.
Naively assumed there would be a physical convention across components, should have checked on a breadboard. Wasn’t until I’d gotten to here that I realised my mistake:
I would never use pin numbers with potentiometer symbol at schematic so I would don’t care how they are numbered. Of course designing PCB you have to think a little and may be mirror the symbol at schematic.
