KiCad 6.0.9
I have a new schematic library component and also a new pcb library component,
how can i share a value in “Library Symbol Properties” like “Reference” , “Value”
between schematic component and its Footprint?
Thank you.
KiCad 6.0.9
Thank you.
Have you assigned the footprint to the symbol in the schematic?
yes, i assigned.
indeed, i want to pass some text between schematic and pcb for each component.
schematic:
library:
PCB:
here in PCB, i need the “Description” be “SOMTHING” as i set in schematic field.
The field name in the symbol is Description, so you have to use ${Description} in the footprint text.
My problem solved, thank you.
