Hi all, I am wondering:
- if there is an SFP (small form-factor pluggable optical trasciever, for telecom) footprint (and cage) in the standard libraries - or if someone is working on it?
- In my designs I’ve always used the 20-pin SMD connector togeter with the THT metal cage (that guides the pluggable SFP). Would this kind of hybrid footprint consisting of an SMD connector + THT cage be accepted into the libraries?
- if they need to be separate components, what mechanisms exist for ensuring correct positioning/alignment between the two connectors?
- Does anyone know if there are mechanical differences between SFP (1Gbit) and SFP+ (10Gbit) standards, or would the same footprint work for both?
I have been using this footprint:
specifications e.g. here:
SMD connector: https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=1367073&DocType=Customer+Drawing&DocLang=English
Cage: https://cdn.amphenol-icc.com/media/wysiwyg/files/drawing/u77a1118xx0x.pdf
Thanks!
