Setting Zone's electrical properties - minimum width through Design Rules
Situation: I’m importing another board from Altium to KiCad (KiCad 8). The issue I’m facing now, is that some Altium’s rules can be applied by default on planes (zones in KiCad).
Here’s a picture after import:
I have several zones with this issue and if I update one of them, KiCad’s default values take over and the zone’s connection is broken:
In my opinion, I could apply one rule that will be applied to all zones, like in Altium.
I tried the following:
(rule width_zone_to_pads
	(condition "A.Type == 'Zone'")
	(constraint track_width (min 0.1mm)))
without success…
I could change the attribute on every zones, but it is a waste of time (as I got several, like said previously):
As I saw in the PCB file, this attribute is called min_thickness:
        (zone
                (net 1)
                (net_name "+3V3")
                (layer "B.Cu")
                (uuid "removed")
                (hatch edge 0.5)
                (priority 81)
                (connect_pads yes
                        (clearance 0.5)
                (min_thickness 0.25)
                (filled_areas_thickness no)
I’m already messing around a lot with ‘grep’ & ‘sed’ commands, but I’d prefer to use KiCad’s tools, as much as possible.
Is there another way to reach this goal?
Best regards!
  • enable properties panel on left side
  • selection filter: enable “Only zones”
  • CTRL+A to select all zones
  • now change value for minimum width in properties panel
  • ENTER to commit the changed value, LMB-click to deselect all zones, then recalculate all zones
Thanks a lot for the quick answer!
Though, I’m wondering, is it a choice to not have made it possible through design rules?
Just guessing, but track_width is probably the wrong setting for zones. Not sure if it’s possible, though.
