Setting The Default Drawing Sheet Template
Is there a way to set the default drawing sheet in KiCad 6. I generally create larger schematics and every time I open a project, it default to an A4 sheet, which I then have to change to an A3 sheet manually to fit all the symbols on. I might be missing something but I cant seem to find a way to set the default page to A3.
Create an empty project with one schematic sheet file and a layout file and set all the settings the way you want. Then use it to create new projects and all settings are there
