I use KiCad on multiple systems and I want to sync my configurations, libraries etc. by using either a github repo and/or an SMB share on my NAS. The problem now is that my KiCad installation doesn’t change config directory when I use the KICAD_CONFIG_HOME env variable.
I tried setting it in the configure path dialog - didn’t work (as expected as it’s mentioned in the documentation)
I tried adding the paths to my .zshrc file and push the variables with source ~/.zshrc
but KiCad still looks for its config in ~/Library/Preferences/kicad/8.0
Has anyone an idea on how to tackle this without having to manually reload config files everytime I change something on one machine or setting up a script on every machine that runs everytime I close KiCad?
Main systems: MacOS 14.7
Secondary systems: TrueNAS scale with KiCad Container running
I run the KiCad 8.0 Container link to container. I have yet to set up everything as I want it, but the goal is to 1) open designs from any device with web access (like you can with Fusion360 web, just actually functioning ) to show/review them and 2) if needed work remotely on projects when I don’t have access to my main machines
But for this to work as I want it, I need to be able to automatically sync the configs (and projects/libs etc of course but that’s easier)
GUI apps in MacOS ignore environment variables set in the shell, so you have to use a LaunchAgent script. Setting up either or both KICAD_DOCUMENTS_HOME and KICAD_CONFIG_HOME is described here by Chris Wilson.
Close KiCad first, then use Finder to copy the contents of the /Users/MYUSER/Library/Preferences/kicad tree to your new location. Same for documents. Create the LaunchAgent configs, customized to your liking, then restart KiCad.
To activate the configs run launchctl load ~/Library/LaunchAgents/org.kicad.env.KICAD_CONFIG_HOME.plist and/or launchctl load ~/Library/LaunchAgents/org.kicad.env.KICAD_DOCUMENTS_HOME.plist
