"Set Track and Via Properties": locked trace width modified, and clearance not checked
Hi, in 7.0.1 (but probably in previous versions too?), when using the tool “Set Track and Via Properties” (in PCB Editor, menu “Edit”/“Edit Track & Via Properties…”) I encountered two problems:
  1. Even if a track is marked as “locked”, its width will be modified by the tool “Set Track and Via Properties”
  2. The clearance is not checked when the width of a track is increased. I’m pretty sure that, before, if the clearance could not be satisfied when increasing the width of the tracks of a Netclass, the increase wasn’t operated and the track kept its size.
Is this a regression?
Is there a different way to protect widths for specific tracks while being able to modify widths globally for others?
Thank you.
David
Version: 7.0.1-3b83917a11~171~ubuntu20.04.1, release build
	wxWidgets 3.2.1
	FreeType 2.10.1
	HarfBuzz 6.0.0
	FontConfig 2.13.1
Platform: Ubuntu 20.04.5 LTS, 64 bit, Little endian, wxGTK, xubuntu, x11
	Date: Mar 11 2023 17:00:22
	Boost: 1.71.0
	OCC: 7.5.2
	Curl: 7.87.0
	ngspice: 38
	KICAD_SPICE=ON
Regarding your first problem with the “Set Track and Via Properties” tool in KiCad 7.0.1, the tool is designed to modify the properties of all selected tracks or vias, regardless of whether they are locked or not. However, you can still protect specific tracks or vias from being modified by the tool by selecting them and locking them before running the tool. Locked objects will not be affected by any changes made by the tool.
Thank you Bidrohini for your answer.
However, I’m a little confused, I don’t understand the following:
How do you “lock” the tracks then? It’s a bit contradictory with what you say earlier, “the tool is designed to modify the properties of all selected tracks or vias, regardless of whether they are locked or not”.
I tried to lock the tracks that way: select tracks, press ‘E’ (or right-click and select menu “Properties…”) then check “Locked” checkbox.
The tracks can’t be dragged (a window pops up). But the tool “Set Track and Via Properties” can still modify the width of the locked tracks.
This, plus the fact the clearance isn’t checked makes me wonder it’s a bug, or a missing feature…
