Do we have a way to change the order objects are being displayed?
This yellow rectangle was added later, but it is half behind the gray rectangle, however, the border still remains on top, visible.
If I click the gray polygon, it moves it backward and then the yellow one moves up.
Currently no, z-order of objects in schematic is a (not worked on) feature request: No way to change image z-level in eeschema (lp:#1787404) (#2211) · Issues · KiCad / KiCad Source Code / kicad · GitLab
The only exception is a filled rectangle (circle, …) with fill-style set to “fill with body background color” → this filled rectangle stays in the back.
system
Closed
August 13, 2023, 3:58pm
3
