Separate ground NETs
How would I remove a common ground NET between two boards? For example, in the schematic editor, two sections are created that use their own board and would be connected via a board-to-board
connector. When creating the PCB, the grounds are connected together. Is there a way of removing the common ground NET between the two boards?
you uncommon it. Call it GNDA for bord a AND GNDB for borad b.
btw, more boards in a single project is not (yet) recomended, expecially if you are a beginner.
